Hey all. Have a question on removing the right front hub assembly. I have a stuck axle nut. I'm afraid of stripping the nut - it's been that bad. Here's what we, myself and two neighbors, have tried (and I did put a 50/50 mix of acetone and transmission fluid in an attempt to help it break free)...
Impact wrench (I don't have a heavy duty one - 90 p.s.i.)
with socket on nut, hit the socket to see if it would help
socket with 4' breaker bar
socket with 4' breaker bar and a large pipe wrench on the socket extension, beating the pipe wrench while at the same time cranking on the breaker bar
the above after heating the axle nut with torch
I've got to ask...is this a reverse thread? (we briefly tried that too)
BTW, I read that the metal near the "key" needs to be moved out of that key area. Mine was bent but not at the "key" area. I still bent it away from the axle.
First time I actually closed up shop early for the day (I will usually stay out on it til the early hours - 5am - working on it before I give it a rest). I do not claim to be mechanically inclined but because of threads like this one, I have literally saved a couple of thousand since retirement (and thank you all). I am open to suggestions.
