deepcover6
Just cruising down the George Washington Expressway making my way into Georgetown ...there is some huge backup going into Georgetown so I take an exit and end up around 21st & E street. I just stop to let some pedestrians pass on the GW campus area and, as soon as I get going again....the car stalls and cuts off. Felt like was out of gas and the engine stoped. I looked at my gauges and the water temp gauge was all the way up to H. So I pulled over to the side and let her cool off. First I thouht my piston rod buckled due to the heat..but there is no oil leak, no steam, no metal shredding noise. So after an hour or two I decided start it again. It turned but won't start running. I check the car out now that it's cooler. Checked the oil, and unscrewed the radiator cap to check and see if the oil had somehow seaped into the coolant due to the gaskets maybe melting....but nothing. I tried to start the car again and the same scenario took place. I am wondering now if it is electrical. So I unplug the battery and hope it resets everything...........but 10min later when I start it ...same thing. What do you think is wrong...(Terry) anyone...any thing similar occur on anyone elses car ? Oh yeah I just noticed under the fuse box that INJ OR FIP 30A fuse is blown. I replaced the fuse and started it up again and it blew the fuse.
