HOW To Remove Stock Sub Enclosure?
BoOsTiN
Just curious how difficult it is to remove the enclosure. Havent used it in quite some time now. any right ups out there? Tried to search and did not come up with anything.
Thanks,
i took out my stock enclosure. Just 4 bolts. I left the brackets in though. Took, maybe 45 min only because you have to work on your back laying in the trunk with your legs sticking out.
yeah it's pretty simple to remove just the rack. I also did the brackets at a later time and that took about another 30 minutes. I'd suggest removing it all at once if you're going to do it...
