how to remove 2003 Mazda6 radio dash
mazda6&3
2003 Mazda6 and 2005 Mazda3
I have no back lighting and my radio controls do not work on my center dash. Im trying to remove it myself to see if I have maybe some wiring problems or if I need to replace everything... I've looked all over for videos or instructions on how to remove the dash but can't find anything... can anyone help me out?
I have a 2004 Mazda Atenza and bought it at an independent dealer in japan - of course they didn't know about the bolt and had a hell of a time removing the panel. They were going to remove a bulb that went out, and guess what, after they replaced that lone bulb and replaced the panels, other bulbs died.
They called up the Japan Mazda dealer in Osaka and were told that once they remove the panel and need to replace a bulb, they recommend replacing ALL of them. Not sure if this helps but I would call several dealers or other folks on this forum what they think or would do.
Good luck on figuring out what could be wrong with your radio. Did you check the fusebox?
Don't forget to check all of your fuses! I nearly paid to get a in tank fuel pump replaced and found out I just blew a fuse. Also in my earlier car audio days I blew my dashes fuses while changing hu's. Blown fuses happen.
