garretts77
- 2007 WRX VF39'd
Yeah, that is what I plan on doing with the AWR ones. I think that the gap was just too big with the 19mm hole. I don't really expect a problem with these new ones.
macklum said:When I put my MP3 rear bar on my sedan i used the rubber bushings that came withthe stock bar and opened them up to fit the 20mm bar ,i havent had any problems for 2 yrs .
macklum said:The Mazdaspeed horseshoes will not fit on the AWR spacers ,you have to use the ones form your ES . I know because I tried to fit the speed ones
No you can use the stock ES/LX sway bar bushings but have to open them up to fit the MSP bar ,That what I did . It worked great .ChopstickHero said:but the horseshoe brackets from the ES/P5 are too small for the MSP bushings....
edit: i guess the only bushings that can be used are modified AWR bushings... got it...
right...... thanks....macklum said:No you can use the stock ES/LX sway bar bushings but have to open them up to fit the MSP bar ,That what I did . It worked great .
ChopstickHero said:right...... thanks....
the AWR 19mm swaybar essentially the same as the racing beat one?
