How to program a new remote
GoFast
Contributor
2010 Flyin' Carpet
This is courtesy of icspots
Have all the remotes that you are going to be using, maximum of 3, with you when you do this programming as all of them have to be reprogrammed into memory.
Step 1: Open driver side door and leave open.
Step 2: Lock and Unlock the drivers door using the power door lock switch on the door
Step 3: Insert key into the ignition.
Step 4: Turn Key to ON position and return to Lock (off) position. Do this 3 times within 10 seconds. LEAVE key in the ignition in Lock (off) position.
Step 5: Close and open the drivers door 3 times. Leave door open after this step
Step 6: ECU should respond by locking and unlocking the doors once.
Step 7: Press any button on remote #1 twice. ECU responds by locking and unlocking the car doors.
Step 8: Additional remotes, repeat Step 7 for up to 3 remotes total.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series (about 4) of door locks and unlocks. You're done!
Took me forever to figure this out, kept unprogramming my 1st remote
What about programing Remote-start remotes? I am told this is different and my manual that came with the car does not tell me how.
