Here's a little diagram to make your own Voltage Clamp found at miataturbo.net
This resembles the Voltage Clamp made by Flying Miata...
i no way i'm posting this to replace a quality product made by FlyingMiata.com and sold by Protegegarage.com and Speedcircuit.com
Here is the diagram:
parts could be bought from RadioShack.
The hardest part to find is the Pressure sensor.
I was given a part number by the author of this how-to, who actually sells them for 60$ shipped, but the part is only sold in big quantities forcing me to source other parts. The person i contacted at World Magnetic suggested i tried a different part for my purposes from DigiKey and he was kind enough to provide me with a part number.
Parts List:
LED (any color you'd like) LED itself without resistor included
1K Ohm Resistor
7K Ohm Resistor
470 Ohm Resistor
5K Ohm Potentiometer with multiple turns for fine tuning.
Pressure Switch:
Digi-Key Part Number 384-1012-ND
Unit Price: $14.36
Manufacturer Part Number: 9011-904
Description SENSOR ADJ PRESS SW 1.0-4.0 PSI
everything else you should be able to find at radioshack or soemthing
enjoy...
(used by google: 02 voltage cmalp oxygen sensor voltage clamp mazdaspeed protege voltage clamp protege voltage clamp miata voltage clamp diy DIY do-it-yourself voltage clamp)
in no way i will be responsible if you blow up your car into tiny pieces that not even my grandma, who can do a 1000 piece puzzle of a clear blue sky in one hour would be able to put it back together. If you aint' got the ball, walk away!
Parts List:
1K Ohm Resistor
7K Ohm Resistor
470 Ohm Resistor
Pressure Switch:
Unit Price: $14.36
enjoy...
