mothernature
Wow....just want to thank whoever did this write up. Now if I was to do this to a mazda 5, would the bulbs be the same?
im having the same EXACT issue, seems like i have to hit it or keep switching it on and off to get it going, im not sure what the problem is...
Weird question but, I put these lights in and for some reason I have the top center dome light installed and during the day when it is set to door or on it turns on but when its night time and its set to door and on it won't turn on. all of the other lights work when the door is open or when they are set to on but this one. I thought at first that the bulb was bad but during the daytime it will turn on, but as soon as it gets dark it won't light up. I have no idea why this is happening...maybe its a phantom bulb that only comes out during the day? haha
I tried the reverse bulbs, because I wanted more visibility when backing up. (I have a 5% tint back there and it's sometimes scary backing up at night.) The aftermarket reverse bulbs from superbrightleds.com were very disappointing. They're only brighter if you look them straight-on. I determined this by putting just one in and having the other stock. And since there's just a single LED diode on the end, it doesn't cast light in a (close to) 360-degree cone like the stock incandescent bulb does. So you're not taking advantage of the mirror-reflective bulb housing that casts the light. Basically the stock ones were effectively "brighter". I recommend not buying those bulbs. I'll eventually try to discover some other bulb that is brighter. Someone pointed me toward these ones they have on Amazon that have like 15+ LED diodes on them; maybe those work.
could this be why the part with the term "LUXEON" in it listed by the OP isn't any longer available, but they have this instead?
http://www.superbrightleds.com/store/html/images/7440-xLX3.jpg
744x series 3-Watt LED Wedge bulb
Super Bright 3-Watt High Power LED 12VDC - 16mm Single(7440) or Dual(7443) Intensity wedge base bulb - Brightest LED Tail Light bulb on the market BRIGHTER THAN MOST STOCK TAIL LAMP BULBS!
Super Wide 130 Degree Viewing Angle
Select Base type & LED
curious if anyone got this bulb instead...
heyheyhey,,,
thx for the great write-up.! I printed it out and was able to succesfully install all the LED's, with the exception of the reverse lights which I am not planning to change out.
one issue I did run into is regarding the ms3 kickplate. I don't see how it pops out..... I actually scratched it up a bit trying to pry it out. but then I came to my senses, and realized the kickplate has nothing to do with the glove compartment, it is totally separate. the glove box came out easy without touching the kickplate... so why is that instruction in there?.?.
thx!
you all figure this out?
