Mach 3.5 Turbo
- Titanium Speed
Aight, I got an Injen intake and was disgusted by the surging I heard from it. So I went out and bought an HKS SSQV BOV from someone on this forum. I didn't want to spend 1500 or even 300 dollars just to attach it to the car, so I set out to design a cheap flange. My brother really deserves a lot of the credit too. He's a pimp. For the undeducated, to kill your turkey (compressor surge) you will need to put an atmospheric BOV near the throttle body while leaving your stock BPV in place. See this thread for more information:
How To: Kill your turkeys
Anyway, you're gonna need some stuff first. I got everything I needed at Lowes for 16 bucks, including tools. I already had most of the tools though. Here's what you're gonna need:
1 1/4" insert plug (plasic piece, the flange itself basically)
Insert plug picture
2 sink stopper washers (1 1/4" ID)
Washer in bag
Washer pic
1 1/4" ID radiator hose, about 3 inches long
2 hose clamps for the outside of the radiator hose
1 1/4" hole saw (go cheap, they can be had for around 4 bucks)
1" hole saw
Hole saws picture
vacuum line and T-fitting (usually comes with your BOV)
Razor Knife
Epoxy (any thick type will work fine, I used JB Qwik)
And here's the kicker:
HKS flange adapter for a mitsubishi eclipe. See it in this picture. I don't know where to get one since my BOV came with it. Look around I'm sure they're out there.
Eclipse flange picture
Alright, get all this stuff (or eqivalents) before you start because you can't drive your car with a hole in the pipe. I'll post pictures of all the parts when I get a chance, keep checking this thread.
1st, drill out the center of the insert plug using the 1" hole saw, and file the whole smooth. Push one of the sink stopper gaskets down the insert plug until it hits the lip at the bottom.
Hole saw picture
Washer on plug
2nd, disconnect the IC pipe from the throttle body. There is a solenoid or something bolted onto the top of it. Unscrew this first. I just let it hang for now, I'll find a way to attach it late since my BOV is in the way now. Bend the pipe until you have it sitting on top of the battery. Heating the pipe with a hair dryer makes it a little easier to slide off.
3rd, drill a hole using the 1 1/4" hole saw in the IC pipe close enough to the entrance that you can get most of your hand to it. Closer the better. Make sure you know where you want it cuz once you've begun, you're done
The next few steps must be done in just a few minutes, since most epoxies set up very fast. I didn't take any pictures during the process because I didn't want to screw this step up. Sorry.
Mix up your epoxy and slop it all over the rubber gasket on the insert plug. Put a lot on it, but keep it off the ridges. Push it through the hole you just drilled from the inside of the pipe (ridges out). Smear the epoxy all around the edge of the hole, basically make sure it's going to make a good seal. Wipe it off your finger then, or else you're screwed.
Now, you can either just hold the insert plug/gasket/epoxy tight against the inside edge of the pipe until it dries or you can hold up on the insert plug, push the radiator hose over the ridges until it's tight against the IC pipe and tighten a hose clamp around it. This'll just hold it until the inside epoxy can dry. Let it dry for a while, read the instructions on your epoxy for the drying time.
Now, take the radiator hose off the insert plug so that just the insert plug is sticking out of the IC pipe. Mix up the rest of your epoxy and smear it all around the edge of the inserft plug. Push the other sink stopper gasket down the insert plug and into the epoxy. Slide the radiator hose back over the ridges, push it tight, and clamp with a hose clamp. Let it dry. Imagine the pipe between the washers in this pic.
Both washers on plug
That's basically it. Now you have a 1 1/4" OD nipple sticking out of your IC pipe. This happens to be the OD on the eclipse HKS flange, so I just slid the BOV onto the radiator hose, tightened a hose clamp, and I was done. 100% turkey free, and no stalling at all. I can't even bog the engine. You can see it in the following pictures.
Close-up pic 1
Close-up pic 2
Engine bay pic
Check out these videos. They kinda suck and you can barely hear anything, but it's better than nothing. I used my still camera's video function so don't expect much. They're ZIP files, so you'll have to download them and then use Quicktime to play them. Listen close.
Crappy Video 1
Crappy Video 2
Insert plug picture
Washer in bag
Washer pic
1" hole saw
Hole saws picture
Razor Knife
Hole saw picture
Washer on plug
Close-up pic 1
Close-up pic 2
Engine bay pic
Crappy Video 1
Crappy Video 2
