installed today thanks for the write up. The most difficult part was moving the tranny fwd. I used a long slender piece of wood just to gain some leverage with one hand to move it forward while maneuvering the mount out with the other a little unconventional but it worked. It seemed easier to get the dog bone in this way too. Didn't use loctite instead I used anti-seize compound on the threads so I can remove it if needed. I've seen others before snap bolt heads trying to remove. I plan on checking the bolts to make sure nothing relaxed and became loose.
Immediate impressions. First at start up ... I now know what you all mean ... its like I woke her up. Seconds shifting 1st to 2nd was like spreading butter. I almost felt like I was driving my accord again.
This is pretty comforting because I didn't use loctite when I installed my CS MM inserts. I torqued the bolts to 70 ft. lbs. I'll just give them a check when I do my oil in about 1000 miles. It still feels really solid.
I didn't use loctite either.. but will keep an eye on it everytime I am under the car.
wow this literally took me ~10 minutes if that
rhino ramps FTW
just undid both bolts, took pliers to pull the stock mount out
new one went in easily twisted, then twist it the way it's gonna mount
blue locktite, torqued both to 80lbs and done.
i was expecting MAJOR vibes since so many people complain about it
but the vibes aren't bad at all, even if they don't break in, i wouldn't notice it really. now i havent used the a/c yet so we'll see about that in the summer when i need it.
