I apologize that I don't have all the pictures from this install early last year, but removing the existing Stock Wing is straight forward. I would recommend referring to the service manual.
Once the stock wing is off this is what is left. <O
</O
<O
</O
<O
></O
<O
</O
The green circles (minus one that is cut out of the picture) will be used again by the Autoexe Wing. I used servo tape (double sided foam tape) around these areas to insure a tight water resistant seal around the openings. This will insure a snug fit with the new wing.<O
</O
<O
</O
The blue circles (minus one that is cut out of the picture) are used to help mount the stock wing. I decided to leave the plastic "mounts" in place versus removing them. They are quite tight and over the past year I have noticed that they keep moisture out. You may want to take them out and fill them in.<O
</O
<O
</O
The Red circle is the only one that is left open. I found some "plugs" at the local home depot that make an extremely tight fit. I did not want to fill in and paint..so I went this route. (I will update with a picture soon).<O
</O
<O
</O
With the wing mounted:<O
</O
<O
</O
<O
<O
<O
<O
<O
