how to get 300 whp
guys not to burst the bubble or anything without getting flamed but.............300 hp is not new these days.this can be achieved without going crazy and spending 15000!!!
thats a rediculous price. trust me i build them!:D
pdhaudio said:
s***, give me a price to build me one!
if your serious you can call me and we will talk about it. pm me and ill give you my number . again i am in the process of building up two pro5's right now. mine is one of them. if you were looking for 550 600hp then yeah i could understand the 15000 but thats alot for 300hp dude
Less is always better:cool: . As for tranny Level 10 from New Jersey quoted me approximately 2450 for a fully built auto tranny that would hold 400Hp and possibly more. They also do manual tranny upgrades. Maybe they could do a ball park for you on a manual tranny with LSD and some custom drive shafts that would fit your application. My auto tranny is already beginning to slip just with the little bit I have already done to my car. So my tranny rebuild and my engine rebuild is definitely coming before I start force feeding her.
http://www.levelten.com/
ahhh level ten. who did you talk to ? pat or sam?
i know them . there work is a little shaky and after some bad trannys i dont do buisness with them anymore. they are not very profesional.
Sell your car and buy a Supra:D
You should get abot 14k for the MP3.
Then take the 15k+14k and buy a supra for like low 20 grand.
with the 5k or sol left over you can get 500+whp real easy.
Our pro's will not be to fun to drive at 300whp. You will break tranny's left and right. You will basically lose alot of reliabilty ect.
If you want this to be an all out track monster I understand but to be honest an MP3 feels real balanced at 210whp. Anything over that starts getting excessive for the chasis. Not saying it cannot handle it but for a daily driver and a weekend auto x warrior this is way to much HP.
If you want a really fast car to go in a straight line then well I say go for it:)
This was discussed a while back, read through this thread to find a few answers: http://www.mazdamp3.com/vbb225/showthread.php?s=&threadid=12326&highlight=priceless
Here is a little info on what would be needed.
Lets see, ballpark figure...
Turbo kit - $4000 You could build your own or go with SPOOL, either way expect to spend around this for a good setup.
Forged Internals - $1300 JE Pistons $580 Pauter rods $720 Should hold 20 psi with proper tuning.
Engine Management - $1500 Spool should have this out soon
LSD - $1400 Quaife
Clutch - $300 I would contact Clutchnet and have one made, Kevlar disc
Head Gasket - ??? Would have to get one made
Fuel system - $700 High flow pump, lines, rail, injectors will probably be included in spool's standalone
Tranny
Since no one has pushed the limit we don't know how much the stock can hold. I think it will hold 300 HP as long as you are easy on it. Stronger gear sets are made by Tripoint, so you could go with that.
They are ~800 a set if I am not mistaken and there are 3 sets, so thats $2400 in tranny upgrades.
That is $11,600, not including labor. Very rough estimate, but should be close. You would also need gauges and dyno time and alot of little s***.
So $15,000 would not be far from the cost. Most of the parts are available. Forged internals are available.
spoolin, can u list everything u did to your mp3 for 210whp? would you be willing to help me put together a 210whp mp3 once i get the money together?
$700 for a high flow pump? No way! Try under $300 for a Pierburg in-line pump that can flow more than enough for 20 PSI.
Perf I spoke to Sam. I need a good company for a tranny that is reliable and has nice crisp shifts not to harsh and can hold up to 300HP although I will probally not break 220HP. Whom might I talk to about that. I am running a regular auto tranny not the sport tronic so a swap would not be a big deal. Any help is appreciated.
$700 is an estimate for the entire fuel system minus the injectors. Pump, lines, regulator, maybe a rail, just saying about $700 as it can add up.
let me find out who we are using. because we stopped doing any auto trannys after the mustang debockle with them.
ill find you someone with good references in a day or so.:D
you could probally get 210 with a stage 3 with full exhaust and turn the boost up a lil. or just get the stage 4 when it comes out. that will put you around that mark.
I believe you can make it till 200 HP, if you have 2.0 DOHC 16Valve with 136Hp..
Upgrade with Chip, that will give you about 30 Hp, install turbo, put opened K&N filter that will give about 10 Hp, and with good Muffler about 10 Hp.. I think that will be enough for 200 Hp..
This is my first post here.. I am from Europe, and have a MP3
but with diesel motor.. 2.0 Turbo Diesel with 105 Hp..
I have buy it last year..
Greetz DeX...;)
you'll have like 140hp with those mods.
btw 15k for 300hp? sure if you like getting ***** IN THE ASS.
if i had 15k spare change, id sell my mp3, but a supra, and walk into the 800hp zone
see the fun isnt to spend money on a new car, the fun is to get some parts made and put it together myself.
Similar Threads and Articles
