jeswin12 said:On Step 7, what is the PCM and how will you reset it?
Also, what is IAC and how to clean it?
The PCM is just the term used for the onboard computer. You can reset it by disconnecting the negative terminal on the battery for a while, then going in the car, hitting the brakes a couple times to make sure the system is discharged. Then reconnect it. Word of warning: If you have the factory alarm system (i.e. when you press the panic button the horn freaks out, doesn't just beep in a pattern), it may re-arm right when you connect the battery. Have your remote handy in case you set off the shock sensor (in the case of the P5).
The IAC is on top of the throttle body. It's basically where the EGR is but on top of the throttle body instead of under stuff. You'll need a special torx bit (a security torx bit) to open it up to clean it. I haven't cleaned mine yet, doing just the EGR was enough any time I had rough idle.
