Hi folks,
I've just had the MIL come on in my 99 Miata, and have read this thread with interest. I have a few questions, some info and a suggestion...
Q1. Is it legal to put your car through emissions with this installed?
I borrowed my friends OBDII scanner to get the code (usual, P0421) and was reading the manual with interest. It has a good description of how the O2 sensors figure out how the catalytic converter is performing:
" The computer checks the efficiency of the catalytic converter by monitoring the two oxygen sensors that are utilized in the system, one before (upstream) and the other located after (downstream) the converter. If the catalytic converter loses its ability to store oxygen, the downstream oxygen sensor signal voltage waveform becomes almost identical to the upstream oxygen sensor signal, and the monitor will fail the test."
So, in other words.. the computer compares upstream voltage to downstream voltage, and if downstream isn't smaller than upstream, the MIL comes on.
It seems to me that the mod here just attenuates the downstream voltage enough to make the computer think that the cataytic converter has done its job well.
Q2. Has anyone tried this mod without the cap?
A 1M resistor will surely attenuate the signal enough on its own! What could the cap be for? If nobody else has tried it, I will. It would be a much nicer mod, too: an inline resistor, all heatshrinked up.
Finally, just so I'm sure to get this right:
Q3. It's the O2 sensor *after* the catalyst (downstream) that gets the mod, right?
Any comments are appreciated!
