?How to boost only 5psi?
bumpin_p5
2002.5 Mazda Protege5 SportAuto
Hey Guys and Gals. I have been seeing threads on here saying that a boost controller doesn't lower boost. Then what the hell does? I am getting pretty close to the time of installation for the MSP turbo that I have and I was told by someone that A manual boost controller would lower the boost from the 6.5psi stock down to 5psi. If this is not the case then how would I go around to getting the wastegate to open earlier(at 5 psi)? Any help would be appreciated. Thanks.
A manual boost controller can't do anything to lower the boost.. at all. It can make the turbo spool slower, making it feel more laggy, but that's about it. The wastegate actuator sets the minimum. If you want to go lower than what the stock MSP has, you'll need to source a different wastegate actuator. ATP Turbo sells a couple for the MSP turbo but I think they are higher PSI than stock. If your wastegate has an adjustable rod on it you can also adjust it so that there is less preload on it, which might reduce the amount of boost made but can also have the effect of making it a little laggier.
you can make the stock acctuator work as an adjustable if you cut it and thread both side and use on of the long thead nuts (the real name is slipping my mind, go look at home depot) but lengthening or shortening the rod this will allow you to lower or raise boost...it is a trial and error method though so it might take some time to get it where you want it to be...
Why do you want to run less than 5 psi?
if you replace the wastegate actuator on the t25 with an adjustable one you can set the boost to whatever you want. why do you only want to hit 5psi?
is that an adjustable one?
You of all people Ken, should know that my dumbass is trying to boost an auto. That's why only 5psi.
by the way, still haven't gotten that boost controller and o2 clamp, but looks like I wont need the boost controller anyways. Got an email last weekend that it shipped, but haven't heard anything else about it or seen it yet. Any word on that Mr. Ken?
Maxx Mazda said:
Bah. Be like me. Hit 12psi and melt a piston... Schweeeet! :D
More like hit 12 and leave the tranny sitting on the highway a mile back. lol. (auto)
At least you never have to worry about bending rods on your auto.. I'd rather blow a tranny than an engine any day of the week.
And yes that is adjustable. You can fiddle around with loosening it to see how that performs, though I don't know how accessible the adjustment will be once it is mounted on your car.
Pardon my dumbness, but would loosening or tightening it lower the boost? or shall I say making it longer or shorter lower the boost?
I believe shortening it will lower bost sense the actuator will have less travel and be more responsive...
I dunno. I think the torque converter would jsut slip, would it not?
Well considering they are plastic I think have been known to actually shatter under that much load. Not to mention you would screw up your valve body.
