Callisto isn't on this forum. In fact I think the account he used to join here was banned a year or two ago.
Changing spark plugs is actually quite easy on this engine. You'll need the following:
Spark plugs x4
1/4" or 3/8" drive ratchet with 6" (or longer) extension
8mm and 10mm sockets
14mm spark plug socket
Torque wrench capable of torquing to 12-15 ft-lb (optional)
I think that's all you'd need. There's a few videos on YouTube that walk you through the process.
Here's a more recent one that I found. A note: the right-most (when facing the engine) ignition coil pack has a tube running over it that may make it a little difficult to re-seat the pack over the plug when re-installing it.
Another tip: When torquing down the new spark plugs, it may be a good idea to put a small piece of tape on the socket and the extension, so that they are taped together. This way, the socket will always come off with the extension. There's been a couple of times where the socket didn't want to come off the plug without jiggling it around a bit to free it from the plug.
