The afc adjusts maf and o2 signals via a % not a set value. Adjusting values via a set value is very dangerous to do. When I get back to the office I'll have to take a look at our initial dyno runs but your numbers seem slightly low...not suprising though as the map generally yields a 10whp gain when tuned to the specifc vehicle. Ours was done in a low humidity 76 degree CA day on a relatively stock car. However when we did our runs we did 3 runs spaced 45-1hr a part. Doing runs any sooner than this does not give the car proper time to cool down and will contribute to drifting as turf noted. The biggest contribution to timing retard, excluding the knock sensor, is the coolant and iat temps. As we know detonation increases with heat linearly so the ecu is preprogrammed to increase retard at higher rpms with it received higher temp signals from the coolant and iat sensors... however changin the value of one of these sensors, say for example moving the iat location, doesnt really do much as the ecu just extrapolates from the coolant sensor and knows something is up. Mallard if you can get me the a/f chart to go with that dyno chart I can take a look and make some suggestions on tuning.
