I wouldn't say it's easier or harder to learn on this car than any other, as it is a brand new skill to learn. It is, however, very unforgiving. The resistence of the clutch pedal isn't linear, for the first 2/3rds of the travel is fairly firm and it gets really light at the bottom. The transition point from firm travel to light travel is right around the friction point, too, and this can make it difficult to get a light touch. I've driven stick since I was 17 and first started driving, have probably logged 200,000 miles on 6 different vehicles (a '99 Civic, an '06 Cobalt, '86 OJ White Bronco, '97 Saturn LS1, '07 Mazda 3, '07 Mazdaspeed3) plus driving friends cars here and there plus a few work trucks out on my uncle's farm, and this car still gives me an unwanted shudder or two, especially when cold, but that just tells me I can get better at controlling the clutch.
The advice I can give you for learning any car is to start it moving under idle throttle a few times from a stop to get used to where the friction point is. Just clutch out slowly until it starts to bite and roll forward without any gas at all, and either hold it or very slowly release the clutch as it starts to roll forward. You'll get it rolling at maybe 3 or 4 mph without any throttle input, and start learning where that friction point is. It's sort of important.
Being able to get to that point and hold it without thinking about it is the key to hill starts, for example. If you're good you can hold onto the brake at a stop light on a hill and when it turns green, come out on the clutch right to the friction point, come off the brake and get lightly on the gas as you feather the clutch out and not roll back much at all. You effectively do the same thing with the hand brake, holding the car in place as you partially engage the clutch so you can release the brake and get rolling.
As a new stick driver there are a lot of skills you should learn, like proper downshifting (rev matching), how to handle hills (both up or down), how to read traffic ahead of you well enough so that you're always in the right gear, how shifting slow can be fast and why shifting fast can be slow. These skills become second nature, after a while, and you can learn them on any car. The clutch and the friction point of any vehicle is really a very small hurdle in learning to drive, because once you learn it you've got it (with minor adjustments) for almost any car you'll ever drive. Might take you a week, no matter the car. The bigger, more important, more difficult things to learn might take you years and thousands of miles. I wouldn't worry about the clutch so much. If driving stick intimidates you or you think you won't be happy driving stick, don't get the car. If you're willing to deal with the early awkwardness, go for it.
