2006 Ford Five Hundred:
This is my mothers car that I drive ocassionaly, usualy for errands up to the store or short visits to relatives (and considering it's about 20miles to/back to anywhere, it defentaly keeps a couple hundred miles off my protege). I never really liked the car, it's frecking huge in the first place, it takes a while to get used to the extremely touchy steering(which makes it hard to keep in your lane), espically since there's absolutely no feel to it what-so-ever. Even though it's a 203HP 3.0L V6 the transmission in this car makes it feel rather slow, when you step on it, instead of the tranny going through "gears" like it does on my protege the rev line remains at a constant 3K or so until you let off of it(I'm pretty sure it's using that new ATX tranny that gets better mileage than a manual though), and it dosen't feel all that much faster than my 1.8L ATX. The suspension is acceptable, not soft to the point that if you drive over a cow you wouldn't notice a thing, but just right so that its comfortable, yet you still know that you're on the road. The interrior is absolute rubish though, everything is plastic, and it looks like they tried to embeed a carbon-fiber theme into the dash. while It looks like everything would hold up to the test of time, it still feels like something you'd see in a aveo or focus. Braking is fantastic, it's got huge front brakes and rear ones that are about the size of my front disc brakes. you'd only need to tap them @ 60 before you're back down to the teens. infact I have to be carefull, since otherwise stuff in the car goes flying forward. The car's turning abilities are surprising, at least to me, while it's obvisouly not nearly as good as my protege, I can still take the hairpin and 90degree turns at a rather good speed without hearing wheel chirping or feeling through the dead steering wheel any loss of control Turning radius is pretty good too, I think it's 40" or so. Body roll, even with the soft suspension is rather minnimal, noticable when you come out of a corner, but this is a heavy car so in my opinion it was acceptable, Turning radius is pretty good for a car of this size too. The car does get quiet a bit to the tank, but that's partly due to the size of it; 24-25gallons.. I think it's MPG hovers around the low-mid 20s acutaly. Space in the back is fairly average, pretty good if you've got a 5' 10" driver, pretty average if you've got anyone bigger sitting upfront and they want some decent leg-room. Not so much that you'll be cramped.. but not really alot either. Think of it as sitting in coach on a moderatly priced air plane. While we're on airplanes let me mention the steel plated things they put in this car called Seats.. they're so firm it's absolutely ridicilious I can't believe this is supposed to be an acutal car and the seats are this firm.. the car even has 13K worth of break-in and you have to use a good deal amount of force from your fist to get the seats to give a little.. this makes for a rather bad ride for anything long-distance honestly.. that compared with the fact that if feels like you're almost as high up as an SUV make driving just that more difficult. I mean, it'd be one thing if it were just the driver seat.. but it's the passenger seat, and the rear seats, I honestly don't know what they were thinking when they went this way, but it defentaly wasen't for comfort. There was one neat feature I did like about it though, Ford was defentaly thinking about your average consumer when they made this car, it has built-in maintiance reminders into the odometer, so when you pass every 5,000 miles, you get a message when you start your car (for about 5-6 seconds) that it's time to change your oil. It did this for "check transmission fluid, timming belt, and brakes" at 10,000 miles too, so I thought that was nice. Frankly.. and this is a bit odd to say, but the car is acutaly fairly loud too, I don't know what it is, mabye the new ATX tranny or just the engine, but even at low revs you can defentaly hear a good "moan" of that mass-produced V6 that's in front of you, if it were a italian made V8 it'd be one thing, but this is a rather sickly V6 and honestly I don't really like it.
1998 Chrystler Seabring:
This is my friends car, it's seen about 90,000 miles and it shows it. He's been through three re-manufactured 2.5L V6 engines in the past 10,000 alone and the interior is completly falling apart. the power window control panel is destroyed, the driver door plastic molding is cracked in a couple places, half his center controls don't light up, the cd player dosen't work, he's lost power locks, the leather on the seats look very worn. I'm guessing his was one of the higher trim models, as he's got the plastic wood molding on the steering wheel, a couple other places and leather seats, which while comfortable, don't distract from the car's poorer qualities. which include; crappy brakes, he's got 4 disc brakes and my car with front disc/rear drum does the job much better we both agreed and confirmed, after doing a 60-0 stop, I came out a good 4 car legnths behind him(I should mention though, that his car lacks ABS while mine does have ABS), I can't imagine if his car came with rear-drums, anything less than what he has now I'd be willing to almost call dangerous. the car's fat ass makes turning at even moderate speeds a risk of kicking the back out and spinning out of control or chirping the tires(even though the car came with $800 worth of tires.) It's pretty funny when he drives around with me the stuff he'll say when I take corners faster at places where his car would be to the curb. the 2.5L ATX V6 accelerates a bit faster than my 1.8L does(by the time I'm catching up because of my higher top-end it's only 2-3 car legnths really.) but his top end is still acutaly slower and the ride getting and staying there makes it almost not worth it, when you speed in this car, you're fully aware of it. There's not a whole lot of body roll in this car, but it is still noticably more than the ford and my protege, not something I like, but I guess for it's targeted customer it wouldn't be an issue anyway. Steering dosen't have the dead feel of the ford, you can defentaly feel that you're on the road through the wheel, even though the plastic wood. While it is better than the ford, you still can't really feel much when you start to loose traction like in my protege, you feel it when you're power-sliding, but nothing up until that point, unlike my protege. Suspension is a bit softer than my protege and that in combination with the leather seats gives an acceptably comfortable ride, not good, not bad, just, plain. Turning radius is awfull, it's only slightly better than the ford, which when you compare the size of the two cars is pretty sad. It's got huge 16 or 17" stock alloy rims that acutaly look pretty good on the car. Gas milage for his car is somewhat comparable to the ford, he usualy averages about 17-20mpg doing a mix of highway/city.
It's a coupe but still manages to squeeze two seats (if you can call them that.) in the back, enough for your 2.2 kids.. but no where near enough for any medium sized adult.
