AUTOMATIC TRANSAXLE FLUID (ATF) REPLACEMENT [FN4A-EL]
Warning1. Remove the oil dipstick.
A hot transaxle and ATF can cause severe burns. Turn off the engine and wait until they are cool before replacing the ATF.
2. Remove the oil drain plug and washer.
3. Drain the ATF into a container.
4. Install a new washer and the drain plug.
Tightening torque
29.441.2 Nm {3.04.2 kgfm, 21.730.3 ftlbf}
5. Add the specified ATF until ATF level reaches lower notch of dipstick type of ATF through the oil filler tube.
ATF
Type: ATF M-V or equivalent
Capacity (Approx. quantity): 7.2 L {7.6 US qt, 6.3 lmp qt}
6. Ensure that the ATF level is in the HOT range (65 C {149 F}).
Add ATF to the specified level as necessary.
Hey, we all have a story or two like that. I guess it was while doing my second or third oil change - back in 1976 - that I filled the car with oil, closed the hood, and drove away, only to discover that I hadn't replaced the drain plug. I only drove about a hundred yards before I noticed, so no damage to the car luckily. The worst of it was explaining the mistake to my Dad and then scrubbing the oil stains out of 75 feet of concrete driveway. Such are the hazards of being self taught.Thanks for sharing, glkdcpg. I'm sure we all have done foolish things with/to our cars, but not many of us admit to said deeds in a public forum.
This is embarrassing but after draining the transmission fluid instead of the oil (in the dark in a cold rain to make matters much worse), I was feeling rather gun shy and wanted to confirm that the ATF is added through the dip stick tube. So thanks, now both the oil and the transmission fluid are fresh and I'm back on the road.
