How do I hide wires?????
If it doesn't have visible screws or plugs then most likely it's a "puller". Get hold of an edge and pull with increasing force until it comes loose, don't yank.
yea most of that s*** will jsut pull out, since your only running wire for 1 amp u can probably jsut tuck all the stuff under the inside of the piece. and run it along the left side of the car near the seats.
There's two plastic clip things at the interior cornersand then there's three plastic clip things underneath that mazdaspeed thing. Undo the interior corners and just yank it out. At least, that's what I do (and the dealer) and they're not busted yet. They are pretty strong so you shouldn't have to worry.
But you're putting a jackhammer in an MS3?
yeah i got the sub and amp for xmas so im just gonna start out with what i was given and go from there
