Ah, but can you please explain WHY it is not good practice?
I am failing to see, mechanically, what will cause a problem.
Now please keep in mind also what I'm referring to is NOT popping it in and holding it just to coast (so you are using the pedal/clutch more often), but rather simply holding it in longeri n cases where you need to shift anyway.
E.g., coming downhill, stop ahead. You will have to downshift anyway, just pop it in early and coast up to the stop. Ot, holding it in longer between gears.
Actually, there is a reason that it is not good. When the clutch pedal is in, the mechanism that separates the clutch and flywheel is loaded, and, therefore isn't in its natural state. Basically it puts stress on things.
I don't know the ins and outs of it, but if you do some googling, perhaps you could find something.
I remember reading that if you hold it in too much, the mechanism wears out more quickly. It might even be in the owner's manual.
But in reality, unless you really have the clutch in all the time, I do not think you would really harm anything. These parts would probably last a long time anyway. It's just for the sake of rigor that I wanted to make the distinction.
Peace.
Simple way to lower RPMs...and increased gas mileage
Slap on some 185/75R16s on your car. Will drop highway RPM about 400-450 RPM.
Yes your speedo will be off.
Yes your car will be even more of a dog off the line.
Very insightful first post
