SI Pros IMO= Awesome gear box. One of the smoothest ever. Great sounding, extreemly smooth high RPM engine. Comfortable seat for the long haul. Great looking design in and out.
MS3 Cons IMO= Gearbox is a bit notchy.
I went from a 05 RSX Type S before my MS3. My personal opinion is that the Honda is a fun car to throw around with excellent handling, but no power.
I will add my one complaint about the MS3 is the touchy clutch. Coming from the Honda this thing is just not up to par, but you get used to it after a while.
14 valves/4cylinders = 3.5 valves per cylinder?
I must be missing something. I thought the K20A's had 16?
Do you guys think that if i dont do any modifications on the MS3 engine or exhaust, there will be no problems for at least 50,000 miles?
Also, whats the cost of insurance on the MS3(i am 19). It has to be higher than the Civic si.
I think someone said it earlier...but the the stereo in the Civic is better. (MP3 player!)
....remember that the MS3 while only on a 2 yr production run
The MS3 GT can play mp3s from CDs.
I worked on Acura's/Hondas in the past. Acura had some bad water pumps that would seize, causing the timing belt to break.. Out of 16 valves, youre replacing 14 of them.. Thats what i meant by 14... You break your belt, youre screwed.
Or you can use the aux jack (for people w/ no sat radio) with your iPod and you're set with mp3 music.
