home from the dyno, results inside
kingpinMS3
2008 blue mica speed3 grand touring
246.3hp
283.8tq
dyno dynamics lowboy
http://ca.youtube.com/watch?v=MRCd4aqdQkM
mods:
Cobble SRI
corksport test pipe
ets 3.5" intercooler
SSQ II
TRZ dogbone
Hope the gauge purchase helped with that dyno, lol. Those seem a lil low but humidity=unhappy numbers.
I too, would expect better numbers, even on the Dyno Dynamics. My MS3 with ONLY the MS CAI pulled 239hp and 280lb/ft of torque on a Dyno Dynamics.(idhitit)
Thanks for post KP. I believe we'd all like a/f and whatever data was monitored beyond that. Was the intake temperature after IC measured. Just thinking not being front mount ic maybe shes a little warm. Still very cool post
crazy. its 60 degrees out right now, I just went outside. the car is unreal at the 'warmer' temperatures.
in a perfect world, all dyno's would work the same and be calibrated the same.
I was just concerned that with a top mount if you are not moving enough air through the intercooler. In this picture a front mount would get plenty of air with that fan. But wouldn't you want the fan forcing air in the " ram air " designed grille with hood closed. Sorry obviously I'm new to intercoolers.
yes, which is what the fan was doing.
i know the dyno dynamics are pretty conservative dynos, and it was humid(93%) and mildly warm which are all contributing factors.
i will, however, continue to use this dyno because it's where my baseline was done. it'd be silly to go to another shop and gain +- 60whp when i add a downpipe and cobble accessport.
edit:
i should note that after every run i felt the intercooler to make sure it wasn't heatsoaking. the intake side of the intercooler was significantly cooler than the turbo side.
