Im saying that what i read was that octane rating means the % of octane a fuel contains
87octane = 87% octane and 13% heptane (which is crap that doesnt compress well).
Now i understand that you can't have more octane than fuel itself, so if this is true ... your fuel can't have more than 100 octane which would mean it is made with 100% octane.
so what exactly does 103 octane fuel means ? Since howstuffworks.com says (like i just said) that octane rating = % of octane in your fuel mixture ... it can't be 103%
So i am asking, since i dont think something can be more pure than 100%, what is or what does 103 octane fuel do ?
I know it's not clear ... its late and my brain went to sleep a while ago =) Anything you can tell me about fuel with more than 100 octane would be helpful.
Here's a sample of what howstuffworks.com says:
The name "octane" comes from the following fact: When you take crude oil and "crack" it in a refinery, you end up getting hydrocarbon chains of different lengths. These different chain lengths can then be separated from each other and blended to form different fuels. For example, you may have heard of methane, propane and butane. All three of them are hydrocarbons. Methane has just a single carbon atom. Propane has three carbon atoms chained together. Butane has four carbon atoms chained together. Pentane has five, hexane has six, heptane has seven and octane has eight carbons chained together.
It turns out that heptane handles compression very poorly. Compress it just a little and it ignites spontaneously. Octane handles compression very well -- you can compress it a lot and nothing happens. Eighty-seven-octane gasoline is gasoline that contains 87-percent octane and 13-percent heptane (or some other combination of fuels that has the same performance of the 87/13 combination of octane/heptane). It spontaneously ignites at a given compression level, and can only be used in engines that do not exceed that compression ratio.
I hope it'll help you understand why im confused =)
The full article is here:
http://auto.howstuffworks.com/question90.htm
