hks type 0 install
2010 Subaru Legacy GT
i just bought this like 20 min ago. now i need to find where to put the rpm signal wire. which wire on the car is it or which ecu pin should i connect the turbo timer to?
i said **** going to the ECU, i tapped into the gauges..
if you take out the gauges, the wires are on the second harness from the left,
purple/white is tachometer
and green/red is speed
the red in the green red kinda looks brown really...the wire is closer to the right side of the harness
okay, see where the red LED for the security system is? that black plastic panel has two screws up top. unscrew those, and that plastic peice snaps up/out. (you might have to disconnect the LED, its pretty hard to remove without doing that. then there are 3 screws for the gauges, pretty simple. i found it easier to do that go digging for the ECU and tapping that s*** and running long lines or whatever, since the timer is gonna be right there anyways, why not tap the gauge lines, says i
