HKS SSQV Video Clip
Speedbuny - my bandwidth prob has been eaten up with all the views. Try again later.
Jernut - Custom flange kit I made a while back, I don't know why others have the sound and I don't. Maybe defective valves?
Mazdaspeedturbo - your valve maybe too long from the i/c piping
You want it closest to the i/c piping and the shortest vac line source.
I have the same BOV. HKS SSQV, with hard pipes. My car idles perfectly, in fact better than the stock system. But some of that is the K&N filter is relocated so the fan doesnt blow on it anymore.
My car only flutters if i dont build alot of boost, and shift slowly.
Also, my car does stall if you rev it up and then put it in nuetral or press the clutch in. I just rev match it down, and its fine.
Bump for ppl making it work with stock pipes. This is how it should sound, if not something is wrong.
sounds much quieter than my stock turkey with injen cai, maybe with a cai itd sound a lot better?? id have to say the turkey sounds better than a high pitched queef...
