Ive done quite a bit of searching, and have read alot of the threads on the install diffuculties of a piggyback fuel tuning device on my mazdaspeed protege.
I'm a little confused as to WHY exactly nothing seems to work.
I hear people say its a wiring issue, others say its the ECU, nothing ive read is very clear.
The car tunes fuel by a hotwire MAF, this much i know. There also is no MAP sensor correct?
Well if it tunes fuel by the MAF signal only, then what is the big issue with the car. Does the ECU reject or ignore the signal? I dont see how it could sense it overrides the signal that should be given, and gives it its own, and if it were just ignoring it, does the car just run off some sort of funky base map?
My next major mod plan after a downpipe is a piggyback fuel computer, and then some 450cc injectors, so i can safely run more boost, without fear of detonation.
Timings still a concern, but for a mostly stock setup, it shouldnt be too bad.
So help me out, and give me, and everyone else who wants to know, some insight as to why exactly the S-AFC, S-AFCII, and HKS Super AFR are so diffucult.
Thanks
Thanks
