jersey_emt
- 04 MSM #1089
All the way closed would be infinite boost....if air can't get through it to the wastegate actuator, the wastegate would never open. It would boost until the motor blows.
All the way open will NOT be stock boost, it will be higher. My boost is 7psi stock, and 8.5psi with the MBC at the lowest setting.
The MBC is a restriction in the line...just having it will up the boost a bit.
