Hi,
I would also like to ask to owners with high mileage, other than the regular maintenance, what items did you replace? (water pump?, Fuel Filter?, Transmission solenoid? Engine mount? etc.) Please let us know if these are replaced at what mileage.
2015 AWD here, bought certified in Dec 2015 at 20,000 km, now approaching 43,000km mostly highway (Hamilton-Toronto commuter)
So far haven't done anything to it, runs fine. Taking it in next week for the filler pipe fix and drivers mirror fix. Question I have is, do I need anything more than an oil change now? The 40k scheduled service includes oil change, brake pad clean and inspection, caliper clean and lube, tire rotation, general inspection (or so they say). Also, as I haven't changed the oil for 23,000 km, do i need to do an engine flush?
There's really no mileage penalty with the 2.5, so why order the 2.0?
My driving is mostly highway and per Mazda the 2.0 is almost 10% better highway mileage. The 2.5 has enough moving mass to require a balance shaft which adds another engine chain drive, more inertia, more weight, more cost. My 2.0 is silky smooth, can hardly tell it is running at idle... see
I own a 2016GT with 30,000 miles in addition to putting 40,000 on my 2.0 2013 GT so I am familiar with both engines. I do not find that spirited driving in the 2.0 sent the fuel economy down the drain. Same driver same conditions the 2.0 is 10% more efficient but the 2.5 is 20% more powerful/quicker. I do a lot of highway cruising so that is where the 2.0 shines. Your 2.0 Mazda 3 that gets bad mileage is likely not direct injected (skyactive).
What did you replace yours with?2016 GT with 74K miles. No issues at all. I did just replace the front struts and rear shocks. The fronts actually had a little life left in them but the rear shocks were gone.
