HID Retrofits!!!
JrTekSilverP5
02' TwoToned (Sliver/Black) MP5
OK i think this is what EVERYBODY has been lookin for...
Theres a company in Cali called I l l u s i o n L i g h t i n g and they do custom retrofits (PICS ON THE SITE). Retrofits meaning... they take the HIDs from Audi's, BMW's and whatever other cars that come with them and MAKE UM FIT perfect and WORK perfect... Cut off line and eeerything... The best kit they have is STAGE 3.
Stage 3:
Info:
While stage 2 is sufficient for most people, some want the ultimate in lighting. For those seeking the ultimate in automotive lighting, Illusion Lighting now offers ECE-compliant HID / xenon projectors. These projectors are rated E1 which are the highest rated projectors in Europe. Our stage 3 retrofit utilizes OEM parts to replace your factory reflector/projector with a ECE-compliant HID / xenon projector which will give your vehicle the ultimate in lighting.
Our stage 3 retrofit will result in a beam pattern that is more focused up front giving the driver more usable light. The retrofit will also result in a more intense, non-glaring, and even beam pattern than any projector on the market. This retrofit will give you the smoothest beam pattern available on the market. For
After modifications have been completed the headlamp reinstalls back onto the vehicle like stock, no additional modifications are needed. The only additional work that is required is to install the wiring harness and secure the ballast/igniter which can be done in 10 minutes. Alignment of the beam pattern is still done by using the factory switches.
Kit Includes:
- (2) Xenon bulbs, ballasts & ignitor
- (2) HID ECE-compliant low-beam projector lenses
- Plug-and-play HID wiring harness
Parts condition:
All parts used for this retrofit are completely new.
Applications:
ECE spec HID / xenon projector retrofit is applicable for most vehicles.
Now when i saw this site i was like (shocked). As soon as i could save up the money, I'm GETTING THEM FOR SURE!!!
your welcome guys...
kinda sucks u have to send em your lights tho.. if i had the extra funds id have them make me a hid set with new lights.. so i could swap em out.. player.. if u got tha luchini. -=)
John
If anyone pays 800 for the stage 2 or even 1400 for the Stage 3 they are CRAZY. I recently purchased a set of HIDS and Projectors off 2001 Audi A6 for 230 used. I am currently working on the retrofit and its taking me alot of preperation. The wall they make is a flat sheet of plastic that they cut to fit in the housing and they cut the back of the housing out so they can make the projector fit. Its not a hard process at all as long as you have the patients and do preperation for it you'll be fine. Once i am done i will post a how-to but to spend so much money is just NOT worth it.
