Headlights will require bumper removal. You want to make sure you get the bulb in there correctly without touching the glass or damaging the built-in igniter either. However, it is a very simple, plug-n-play installation. No harness or wiring or cutting is required as long as you purchase a H1 pnp kit.
If you are going to do it,as easy as it is to get the lamps out and apart.I would get the ECE E46 D2S projectors and put those in with a D2S HID kit.You will be much happier with the results,since you won't get beam shake and bad as you would with a pnp H1 kit.
Plus while you have the lamps apart,you could put in a DDE halo kit
