fred_spitfire
- Black Protege 5
Attach the positive terminal of the wiring harness to the positive terminal on the fuse box
there is something i did wrong then? i attached the positive of the harnes directly to the battery
I don't think that's a big deal.
hey guys, im having some troubles because of the DRLs, would it be possible to to switch up and connect my low beams with the corners lights wires and conect the corners with the low beam wires? and where do i find the corners wires?
um, no because then your headlights would come on instead of your running lights up front, and vice versa....
yes. the running lights come on on the first click (all 4 corners) and the headlights are added on the 2nd.
all right i think ill do this to get my HIDs to work properly, where are the corners lights wires so i can switch them up? is it even possible to switch them up?
k, my original point was DON'T do that..
because #1, the circuit isn't meant for that, #2, you're screwing with what comes on in what position (rear running lights with headlights, then front running lights in place of headlights)... its just a bad idea in general, and I don't understand what problem it solved for you.
do you have a power harness or are the HIDs running directly off the headlight plugs?
then you shouldn't have any problems, the DRL should trigger the relay just fine. check your wiring and connections.
do yourself a favor and check the connections.
