Hiboost FMIC recommended??
Keop0007
MSP 3.5 TI
I was looking at the hiboost fmic, who recommends this kit. I'm just planning to run stock psi cuz i dont want to hurt the engine. will this kit be worth it for me and what type of gains can i expect from it. thanks all!!
Definitely worth it. Most gains I've felt from a Mod. (with exception of turbo upgrade)
Not only will you have no heatsoak, you will have consistent performance. Along with that, you can now run a Blow-off valve.
I had the FMIC installed along with the Injen intake which I think you have to do anyway to run the Front mount.
Very worth it. Will net you some gains and like nvmsp said, the performance will be consistant.
I am now able to look at my air temps with Microtech EMS and after the engine is warmed up and I do multiple WOT runs, the air temps changes ONE degree celcius, at most.
i like the kit. the only problem i have with it is that one of the pipes is not long enough. an extended coupler has to be used. i am not the only one with this problem. someone even posted a picture of the gap between the pipes somehwere on the forum. But that is the only problem and all you do is buy alonger coupler and its solved! not a big deal at all. all the parts a great quality and juan got it to me promptly.
i have this kit on my car and it is worth it. Like everyone has said you have constant power from start up to when your done driving. well worth the money and a great investment for any msp owner.
haha i had the same problem too
