xlilmikeyx
I am working on my friends 2003 Mazda Protege(ES/not turbo). Coolant is backing up and easy test is to replace the thermostat. Here is my problem. Every DIY/picture I see a 2 bolt housing. This housing is 4 bolts but one bolt is blocked by the copper pipe exiting the exhaust manifold and around the engine towards the firewall.
Anyone every seen an engine with this? Is there anyway around removing the pipe since getting to the one side would require me to take off the throttle body(atleast).
Would removing the pipe from the manifold only allow enough flex to remove the blocked bolt?
I thank you for your help.
