the turbo on the car is plenty capable of blowing the engine up AS IS!!!!!!!!! the stock turbo has FANTASTIC spool speed and will easily give you 12-15psi WITH APPROPRIATE ACCOMMODATING MODIFICATIONS!!
being said.. first things you should be looking at are:
boost gauge to know your psi levels
Air / fuel ratio gauge (WIDEBAND o2 REQUIRED)
exhaust help, if even just downpipe.. stock DP is one of most restrictive parts, exhaust-wise, on these cars, very small, very tight curves..
after these are addressed.. then you can look at POSSIBLY increasing psi, which will of course give more hp.. but there has not been much success in going over 8-9 psi (10 MAXX) on stock engine block.. (cars come stock boosted at about 6 psi) ..
for this you need boost controller.. but FIRST, you must put in your research..
everyone has to start somewhere amigo, look around, ask around.. people will help!
