Help! My lights behind my temp knobs are out?!?!
AWDSpeed6
2006 Mazda Speed 6
Hey guys, My lights behind my two of temp knobs went out after I installed a aux port.
Any suggestion why they went out? All the connections are tight and everything is right.
Ill replace them if needed just wondering why they went out if I never messed with the bulbs.
Thanks
Is it just those? Then it's probably the bulb. When you install stuff, it's easy to cause an issue that blows a fuse or shorts a bulb. The fuse for the panel lights is under the hood, don't recall which one it is right now but you should see something about the dash in the fuse list. Since it's just the two lights, it's probably just whatever bulb is there, when you blow the fuse all the dash lights on the console go out.
