Help ms3 won't start!!!
mazda_dan,
I apologize if you have been having trouble getting in touch with us. We have been fairly busy with several things, but I am not aware of any reason that you would have been put on hold without further assistance.
We can definitely assist you in getting your car back up and running. If you would like to send the ECU and AccessPORT to us, we are more than willing to revert the ECU to stock programming, reprogram the AccessPORT, test everything to make sure communications are functional, etc. If you would like to do so, please email me directly at shayne@cobbtuning.com and I will get the ball rolling for you.
Again, I apologize if you have had trouble reaching us. I know it can be very frustrating to deal with a non-functional vehicle and not feel like you are being properly supported.
Let me know if there is anything else I can do for you.
Shayne Covey
Sales/Tech Support
Might want to check the white plastic covered relay connector on your Starter that tells Starter clutch is in. It can get corrosion in there and with no connection car won't start, everything eles will work. Unclip it, clean male plug on starter and clean inside of connector(used an Xacto knife) spray some CRC , crimp the connector a little so when you plug it back on it doesn't move around. This baffelled the dealership and they couldn't find the problem.
