CRANKING PROBLEMS
Should you discover a cranking problem when you attempt to start the engine, you can focus your attention on the starter. A quick way to diagnose cranking problems is to switch on the headlights and watch what happens when you attempt to start the engine. If the headlights go out, a poor battery cable connection may be strangling the flow of amps. All battery cable connections should be checked along with the engine-to-chassis ground straps.
Measuring the "voltage drop" across connections is a good way to find excessive resistance. A voltmeter check of the cable connections should show no more than 0.1 volt drop at any point, and no more than 0.4 volts for the entire starter circuit. A higher voltage drop would indicate excessive resistance and a need for cleaning or tightening.
Slow cranking can also be caused by undersized battery cables. Some cheap replacement cables have small gauge wire encased in thick insulation. The cables look the same size as the originals on the outside, but inside there isn’t enough wire to handle the amps.
If the headlights continue to shine brightly when you attempt to start the engine and nothing happens (no cranking), voltage isn’t reaching the starter. The problem here is likely an open or misadjusted park/neutral safety switch, a bad ignition switch, or a faulty starter relay or solenoid. Fuses and fusible links should also be checked because overloads caused by continuous cranking or jump starting may have blown one of these protective devices.
If the starter or solenoid clicks but nothing else happens when you attempt to start the engine, there may not be enough amps to spin the starter. Or the starter may be bad. A poor battery cable, solenoid or ground connection, or high resistance in the solenoid itself may be the problem. A voltage check at the solenoid will reveal if battery voltage is passing through the ignition switch circuit. If the solenoid or relay is receiving battery voltage but is not closing or passing enough amps from the battery to spin the starter motor, the solenoid ground may be bad or the contacts in the solenoid may be worn, pitted or corroded. If the starter cranks when the solenoid is bypassed, your patient needs a new solenoid not a starter.
Most engines need a cranking speed of 100 to 200 rpm to start, so if the starter is weak and can’t crank the engine fast enough to build compression the fire won’t light. In some instances, a weak starter may crank the engine fast enough but prevent it from starting because it draws all the power from the battery and doesn’t leave enough for the injectors or ignition system.
If the lights dim and there’s little or no cranking when you attempt to start the engine, the starter may be locked up, dragging or suffering from high internal resistance, worn brushes, shorts or opens in the windings or armature. A starter current draw test will tell you if the starter is pulling too many amps.
A good starter will normally draw 60 to 150 amps with no load on it, and up to 200 amps or more while cranking the engine. The no load amp draw depends on the rating of the starter while the cranking amp draw depends on the displacement and compression of the engine. Always refer to the OEM specs for the exact amp values. Some "high torque" GM starters, for example, may have a no load draw of up to 250 amps.
An unusually high current draw and low free turning speed or cranking speed typically indicates a shorted armature, grounded armature or field coils, or excessive friction within the starter itself (dirty, worn or binding bearings or bushings, a bent armature shaft or contact between the armature and field coils). The magnets in permanent magnet starters can sometimes break or separate from the housing and drag against the armature.
A starter that does not turn at all and draws a high current may have a ground in the terminal or field coils, or a frozen armature. On the other hand, the start may be fine but can’t crank the engine because the engine is seized or hydrolocked. So before you condemn the starter, try turning the engine over by hand. Won’t budge? Then it’s going to take a lot more than a starter to revive this patient.
A starter that won’t spin at all and draws zero amps has an open field circuit, open armature coils, defective brushes or a defective solenoid. Low free turning speed combined with a low current draw indicates high internal resistance (bad connections, bad brushes, open field coils or armature windings).
If the starter motor spins but fails to engage the flywheel, the cause may be a weak solenoid, defective starter drive or broken teeth on the flywheel. A starter drive that is on the verge of failure may engage briefly but then slip. Pull the starter and inspect the drive. It should turn freely in one direction but not in the other. A bad drive will turn freely in both directions or not at all.
