word the **** up!
if this is the first time taking off the bumper, this is what you do...
turn the wheels to get in the wheel well. un-screw those clips, 2 or 3 if i recall correctly, reach in the fender and undo the bolt that's in there. repeat for the other side.
pop the hood and undo the clips, 6 if i recall correctly. and the two phillips head screws.
now you will need to undo the undertray. there's about 13-14 phillips head screws there as well. and one st00pid ******* clip that doesn't come undone unless you rip the s*** off.
now pop the bumper from the sides off of the fenders. grab it from the front and pull. there are still clips holding the s*** in, soooooooo, you'll have to lift up a bit to get it off of those clips.
now, undo your fog lights.
now get that s*** off of there, fix your power steering cooler and repeat steps to get your car back to normal.
