HELP: Crooked line in front of radiator?? Anyone elses?
Status
Not open for further replies.
in front of the radiator like oaklands. there is a bracket on the driver's side of the power steering cooler, and a place where it attaches to...
The amb temp sensor... is for what? Telling you the temp outside?
yeah. idk if sports have them. idk if you have sport or not. but on the head unit, there is a display for the temp. and there should be a button next to your rear defrost button that says amb to display this information
Yea, I got an AMB button, when I hit it, it reads ---
Im guessing when they fixed the car they didnt put it back or replace it.
I do see the bracket on the drivers side thats not attached I will assume the passenger side is not bolted on either... since that is the lower side of the 2.
word the **** up!
if this is the first time taking off the bumper, this is what you do...
turn the wheels to get in the wheel well. un-screw those clips, 2 or 3 if i recall correctly, reach in the fender and undo the bolt that's in there. repeat for the other side.
pop the hood and undo the clips, 6 if i recall correctly. and the two phillips head screws.
now you will need to undo the undertray. there's about 13-14 phillips head screws there as well. and one st00pid ******* clip that doesn't come undone unless you rip the s*** off.
now pop the bumper from the sides off of the fenders. grab it from the front and pull. there are still clips holding the s*** in, soooooooo, you'll have to lift up a bit to get it off of those clips.
now, undo your fog lights.
now get that s*** off of there, fix your power steering cooler and repeat steps to get your car back to normal.
word the **** up!
Ive got the full service manual (wiggle) Thanks
what are you doing replying...shouldn't you be working on your car?
Shouldnt you be hovering in the sky above me with your god like sunrays to melt the snow and warm the temperatures above 8 degrees so I dont go into hypothermia?
Hehe sorry man that was an atypical post for me. I've had a few cold carbonated beverages and was feeling frisky. You should see the concerns I come up with for the car!
paranoid? Look... when you see something hanging down in your car that you know shouldnt be, you SHOULD BE concerned. How that makes me paranoid.... well I guess maybe we have a different definition of the word. Id appreciate if you keep the ignorant comments to yourself.
Status
