HELP:18'' & 45offset 2''drop?
jordafella
2008.5 M3
As the title says will that set-up work:18x8 45offset (225/40/18) with the tein s tech drop? thanks for your help!
if if helps im running 18x8 with a 42 offset and tein stechs, dont know if you have adjustable rear camberlinks or not, but if you do, add a lil more camber and roll the rear fenders and you then you might be ok... all i can say is try, you know it can be done since mine stick out farther than yours would... its jsut a matter of making it work
