10 psi won't get you 250 on the t25. You will more than likely see anything around 200-215. The cams won't give much since they are just fsze cams. Im pretty sure there is a gain though. I didn't really notice much, top end felt a little nice but that could have been my imagination. headwork is definitely a plus, but the 626 mani is hit or miss. Some see gains, others didn't notice a difference at all. If anything, some have lost torque in the mid range. Can 250 be done? sure, with a rock solid tune and probably knock detection, hell use meth injection for added safety. For a built motor, dump the t25 and pick up a t28 or bigger. t28 should be all you need though since your power goal isn't that high.
For reference, Knox Joe did 241hp on stock block. I don't know if he was on a t25 or not though. He is using a standalone EMS and meth injection.
