That makes sense. How do eliminate or lower the amount of heat soak you are getting to a SMIC? would upgrading stock have any impact on this? Thanks for helping me understand....
HUGE impact.
right now, your stock intercooler is smaller than the sheet of paper in your printer, AND it is tucked back behind the bumper so that no ambient (outside) air can reach it. Go read how intercoolers cool the charge air, and you'll see that if the only air around it is already hot from the engine bay, it cannot do a very good job heating it. Also the bigger it is, the better it cools, and our stock is TINY.
From those 2 things it would make perfect sense that a larger intercooler located at the front of the car in the lower grill will cool a hell of a lot more than the crappy smic. This is called a fmic -- a Front Mount InterCooler. Most fmic's that you see are at least 3x the size of the stock smic, and are again located in the front of the car so that air cool air passes through it as you drive along.
Upgraded the smic to a better will help a ton as well for 2 reasons. 1) better flow capacity -- the stocker is very restrictive in the amount of charge air it lets pass through with ease. 2) it is only so-so in the heat dissipation compartment. Upgrading to a customMSP or turbohoses smic will help muchos because they have better flow and cooling capabilities.
FMIC will cool more than SMIC hands down, it's a matter of flow, drivability, boost, and money. more boost = hotter temps = more cooling needed = bigger IC. the general rule around here seems to be if your 9psi or less, smic will work fine -- although fmic will always cool better and give you more power. hope that helps.
