headlight adjustment not working
Rubasu
'07 MazdaSpeed 3
hi all I am having an issue with the feature on my 07 speed3 that moves the headlights beam up and down with the switch inside. it is not working at all and was wondering if anyone has had this issue or which fuse I should check. or even if someone has a copy of the wiring diagram for the circuit... thanks
rubasu
How are you checking to see if they are working? The movement is very subtle at close distance
I don't know what fuse it might be, but check the panel and see if its shown on the cover
Double check to make sure the plug to the adjuster behind each headlight is plugged in? Also, see if the leveler is maxed out in either direction. The projector sockets in the headlight might have popped out...which then means you'd have to bake open the headlights to pop them back in. I doubt it's the latter, but just throwing out possible causes.
