headlamp removal?
Mazda 6 iTouring 6MT
has anyone removed their headlamp and if so what's the easiest way to do it? from what I can see you can either remove the entire front bumper or remove the plastic panels above the grill but then I would have to drill out the rivets holding it in. ideas/suggestions would be much appreciated, thanks!
You need to remove the bumper because there is a 10mm hex bolt behind the upper corner of the bumper
np. if you don't put that hex back on, then in the future you wouldn't need to remove it. I wouldn't though, as it may introduce rattling or something.
