igdrasil said:I dont know the exact compression ratio...I will get them to be measured...but im sure is HIGHER!
Wanna be the guy who does this for us? Finding an MP3 around here to begin with is a pain, much less a dealer that would be willing to do this!Glowspeedp5 said:If you know somebody at the dealer it is possible... You hook the MP3 to the computer first. Do an ecu read function.... Its takes about 15 minutes... All the data comes to the screen... Some of the variables are adjustable with the Mazda computer......save data.. then with the Protege5 next to the MP3 you connect to protege5 under the hood then click set prameters then click yes boom 15 to 20 minutes done... Ecu reflashed.........
SOHC pistons in the BP are good for 8.2:1 compression. I don't understand why someone would want to do this though, since the BP is made to handle plenty of boost to begin with.flat_black said:Actually, the SOHC and DOHC motors probably both have different deck height and probably different volumes on the head, so compression is a hard-to-call thing... Any Mazda F/B series piston using an 83mm bore would presumably work, though not always with the stock pins and whatnot. However, if you are talking in comparison, the BP's in the Protege's of the second generation, as well as the new FS/FP engines all have 9.1:1 compression ratio; No higher than stock. The SOHC BP of the first gens, though, had 8.9:1 compression... The .2 probably wouldn't make too much of a difference, though, for those running turbos. The 2001 and later BP engines in the Miata's had a ratio of 10:1, I beleive, though.
We will try this the in the upcomming weeks....so ill let you know.Gen1GT said:If you need custom rods, what's the point of doing a cost cutting mod like BP pistons? Full floating pins could work too, but not 1mm worth of float. And also, you don't know what the deck hight will be once installed. I have no experience with custom pins, since everything I've used in the past has been spec, but I'd like to know how you put 20mm pin in a rod designed for 19mm. I'm not sure I'd want to machine 1mm off the FS rods....
I'm not saying this is impossible, but it's not going to be a drop-in kind of thing.
