Anything can be changed. It is in the software so if its reprogrammed then it will be OK. Once we have our PNP out I'll let you knowtwilightprotege said:so perf can my ecu change the vics activation point?????????![]()
perfworks said:I think it will fall very slightly. Maybe not enough to notice but i'm not sure.
shinzen said:yeah, I totally agree, but an an intake from an older probe is pretty cheap compared to a good P&P job- that's why I got a bit confused.... If it's a direct bolt on and adds more than a few whp it might be a worthwhile mod...
That actually comes from perfworks, from what I understand, it is single runner, no VICS, I like the idea of extrude honing it, or maybe a mild port and just smoothing, but I think I'm going in a little different direction from twilight now, I'm looking at smoothing airflow and increasing velocity to try to build torque. A single runner without any obstructions would suit me, but right now I've got a ported stock P5 mani and an MP3 mani to play with. I'm going to see what they can do first, well, after I get some cams, if Sunbelt would ever get them released, grrrrr.... I would think there are also some concerns with the probe, or is it 626?, mani just "bolting up". Stuff like the EGR valve, fuel rail, throttle cable, cruise (if you want to keep it). But they are cheap.shinzen said:wrench, you mentioned the probe IM swap- does that go to single runner design? And would we pickup some power? Or did I just comepletely miss something?
Did you ever find out how much of an increase you got off of your IM p&p job? or I guess more appropriately, did we find out what the cfm is stock for us??twilightprotege said:yes vics is a good system, just carried out poorly.
and yes, a good p&p will yield 25% increase in air flow. just think of a cylinder. say the stock is 30mm in diameter. that's a cross area of 706.55mm2. and that's rough. increase the diameter to 35mm (not much of an increase really) and you get 961.63mm2 area and that's smoother. just the area is a 27% increase....then you start talking about decrease in turbulance and flow....50% increase in flow isnt that difficult to get
I am going to be lazy and ask. How did you remove it? If you disable the actuator with out taking the intake off to try and remove the flappers, which way do you zip tie the actuator lever?twilightprotege said:it can be removed fine, just dont diconnect the controler for it. you'll throw a cel
Porting is no problem for me, but I too would like to have pics of the mods needed to completely eliminate these flappers/valves. (uhm)twilightprotege said:beavis, can you do me a favour with the spare manifold...take pictures of the lower half of it and confirm if the VICS runners only go to a chamber and in no way connect to the plenum???
(uhm)perfworks said:Couple things, First you can eliminate the rattle two ways (for the VTCS ONLY) Adjust the lever screw right below the actuator. Second just unplug the vacuum line and plug it with a screw or something and clamp it.
The rattle comes from the plates hitting the reversion lip inside the manifold.
Second the VICS. The plates are open when manifold vacuum is not present. It is supposed to provide more low end torque.
When the plates open it adds more "capacity" to the system like a shorty manifold would for top end breathing. How well does it work? Ok for economy vehicles but a nice 98 626 manifold that is of single runner design would be much better for FI applications.
BTW the TB (no wiring difference) is the same and all that would need to be done is rerunning the fuel lines. You could keep the stock 626 injectors in there.![]()
