Hardpipes are installed!!!
ok I just checked right now and everything is in their right place, when I test drove my car again, my cars turkey noise got a little deeper, and it seems like more air is coming through the car is this normal.
It is definitely going to flow better because of the hardpipe and smic and the turkey noise will be a little louder. When you install the cold pipe and bov are you doing a maf relocation?
Myspeed12 said:
and how do you know if the code is fine
When they scan the car it will tell them what the code is. When they tell you the code and reason for it let us know. It could be something stupid like an 02 sensor or it could be more....
So i talked to a worker at autozone and he said I gotta buy the do it yourself they sell to check it myself, I asked him if it was free and said no, what dick man.
Yea....you can put it on a CC...then they just credit it back...same as free...
(poke)
Truthfully I'd buy one, or actually I did. I have a cheap but basic scanner. UIt tells you the code and it'll give you a basic reason for the code to help you find the problem cheap and effective. It wasn't too expensive. I think it was $200 but I got a store credit with it for $50 which I used for oil and stuff.
does your cold pipe sit a little crooked at the bottom of the intercooler? mine does I think mine was bent a little wrong...it doesnt sit very flush and I had one hella of a time to get it to connect on both ends!
Myspeed12 said:
well feeling the coldpipe it seems like its on...would their be any other reason.
need to find out what the cel is for before we go any further
You are refering to the new SU coldpipe? I have yet to put mine on...any tips are appreciated...
tips....hmm..well mine was a really tight fit... i mean really tight! you might wanna get your intake outta the way for some more wiggle room...just put the cuplers on the throttle body and the intercooler first then go from there....watch out for that damn screw by the battery that sticks up...it scratched the hell outta my pipe...other than that your golden
