Hardpipes are installed!!!
Myspeed12 said:
how low is your flange on the coldpipe? for the BOV, so it dont hit anything
Well mine is just at the bottom of the straight section but if you have a cai it will be in the way there if you are using a stock intake or an sri you should be ok. Test fit the coldpipe first and see where the best location is for you.
www.ms3forums.com
after spending $2,800 and countless hours in making MAZDASUMMERPALOOZA a success, and making sure it doesn't flop with this forums name on the sponsor list, these jokers bleep out everything to do with SU cause ken at pg takes his problems to a forum admin instead of to me.
<!-- / message --><!-- sig -->
www.ms6forums.com
Earful said:
You are refering to the new SU coldpipe? I have yet to put mine on...any tips are appreciated...
Had fitment issues...going to try SU's advice and move battery a little and twist pipe alittle to make fit better...
